Can't open Audacity
Hello: I downloaded audacity-macosx-ub-2.0.6.dmg yesterday and installed it according to the instructions.
When I try to run Audacity I get the error message shown in the attached screenshot.
When I delete v 2.0.6 and reinstall v 2.0.4, I get the same result, although it used to run without problems.
What should I do to solve this problem, please? (v 2.0.6 reinstalled)
MacBook Pro
8GB
OS X 10.8.5
Did you do your system upgrade recently? Go into your Mac system preferences (Apple > System Preferences > Security) and make sure your Applications permissions are set as in the attached picture. Also, it may not let you install it if you’re not on-line.
There’s also a way to override that restriction.
http://support.apple.com/kb/ph14370
That may work the same way in Mountain Lion.
