So I am on windows 10 using 3.0.0.
I can record tracks no problem, I can monitor them after they are recorded, however, while recording the new track - I can’t hear/monitor the live rack being recorded? I can hear/monitor all the already recorded tracks, just not the one being recorded at the time. I am sure it is some stupid setting mistake on my part, but I can’t figure it out?
You can’t listen to the computer to get your own voice or instrument because that connection will almost always have a delay or echo and it’s impossible to perform to it. You have to do it with your interface, preamp, or microphone.
If your connection doesn’t lend itself to doing that, then “Perfect Overdubbing” is not for you.
