Can't Install Voxengo CurveEQ or any other Voxengo Plug-In
Hello,
I’m having trouble installing the Voxengo CurveEQ or any other Voxengo Plug-In. I’m using Windows 10 and Audacity 2.3.2.
Here is the error I get:
https://i.imgur.com/OChdXRVl.png
I’ve tried running in admin mode, installing only the 32 bit version of the plug-in, etc. and still can’t get it to work. People are claiming that this plug-in works with Audacity, so not sure what I am doing wrong.
Any help is appreciated. Thanks.
Bad link in your post.
What’s the error message (in words)?
Failed to register. Could not load the library.
Who is claiming this? Do you know which version of Audacity they are using? Are you able to contact them to confirm if you have the correct version of the plug-in?
The demo works for me.
I installed the 32-bit VST version into it to the regular Audacity/Plug-ins folder and it created a Voxengo sub-folder. It installed one file (CurveEQ.dll) in that location.
It showed-up under Effect _Add/Remove Plug-ins → New, and I enabled it. Then I was able to select & use it.
What version of Audacity are you using?
Audacity 2.3.2. Windows 10 64-bit.
