Can't Hear Voice through Head Set
O.S.: Windows 10
Mixer: Behringer H1204
Headset: DT 770 Pro
I can not hear my voice while recording. What setting should I use on the mixer and on Audacity. I have the headset set jack plugged into the Behringer phone jack. Mixer connected to computer via USB.
Many thanks for any assistance. Dick Lee (rleekgb@comcast.net)
Check your user manual for the mixer. If you plug the headphones into the mixer you don’t have to worry about the computer. :slight_smile: And there is a BIG advantage that you avoid latency (delay) through the computer.
There should also be a way to include a backing track (from the computer) in the headphone mix, if that’s what you want.
NOTE - It’s a bad idea to publish your email address on the Internet. There are spam bots that harvest email addresses.
Plus it’s usually helpful to keep the discussion public so others can learn from the discussion or link-back to it when answering another similar or related question.
