CAN'T HEAR ANYTHING AT ALL!!
I have Windows 10, and am currently using Audacity 2.2.2.
I have opened downloaded songs and cut them. Before cutting the songs, I was able to hit the play button and listen to the song. However, now, after cutting them, I try clicking the play-button and nothing plays. The play button is practically frozen. I have 10 separate tabs of audacity open with different songs. PLEASE HELP! I need these for a wedding!
Can you export the files?
I have opened downloaded songs and cut them…
…I have 10 separate tabs of audacity open with different songs.
Sorry, I don’t understand what you’re trying to do. Typically, you’d work on one song at a time unless you’re trying to combine several songs into one long show, or unless you’re trying to split a long recording into separate tracks/clips/songs. Either way, you shouldn’t need “10 tabs open”.
