In the drop down menu - “apollo twin thunderbolt” is not appearing as an output option anywhere.
I am only able to listen on my terrible laptop speakers
Im on 10.14.4 mojave
Even the System?
Apple (upper left) > System Preferences > Sound > Output.
These System panels have a volume control in addition to other settings. Does your soundcard have drivers or helper software? If you have a complicated enough soundcard, it may not “look like” a soundcard to Audacity. For one example, Audacity will not play back multi-channel and sometimes if you get the mono-stereo settings wrong the soundcard won’t show up at all.
