I desperately need help with this issue. I’m fairly confident that the room I’m recording in is sound proof enough. I’m in my closet, wool blankets on the walls, I use a mixer and an audio recorder. I keep getting the room’s normal white noise in my recording. When I use noise reduction (with the sensitivity set to zero, then nothing changes on the recording. When I use noise reduction (with the sensitivity above zero) then it ruins my recording. It will make certain vowels sound muted, it ruins my ‘s’ sounds, etc. What should I do!?!
If you just can’t make it work, create a forum test clip and post it here. There are some microphone systems that can have very difficult sound problems.
You might consider what would happen if you don’t make a very quick deadline. The forum elves do a very good job, but it can take a day or two…or more.
This is a brand new system, right? You haven’t been using it OK for months? Do tell us what kind of computer and which Windows you have.
