I downloaded and installed FFmpeg but I can’t find it in Audacity.
How can I find it ?
The preferred way, on Linux Mint, to install ffmpeg is to use Driver Manager to install the codecs packages. You should be good to go after doing that.
ATB,
Neil
In Debian / Ubuntu / Mint … If you use the standard repository version of Audacity, FFmpeg (and LAME) is usually installed by default and Audacity’s “Libraries” menu is hidden. If you are unable to import / export formats supported by FFmpeg / Lame, then as Neil wrote, you may need to use Driver Manager to install the codecs packages.
In Flatpak / Snap packages, FFmpeg may not be available due to the application running in a “sandbox”. Either it will be available by default, or not at all. Questions about Flatpak / Snap packages should be directed to the package maintainers.
