Can't export to external USB drive
Hello Audacity Users,
I have used Audacity to edit and track mark a 121 minute mix I have created. I recorded the mix in WAV format and used the add label At Selection function. When I try to save the mix with the label format using Export label function I get an error message pop up ‘Cannot export audio to’ my hard drive location which happens to a an external thunderbolt drive.
MacBook pro 2011
Mac OS 10.10.5
Audacity 2.1.2
Attached to this question is a screen shot of the event. I hope that this is useful.
Chris Hardway
Best to post new questions as new topics rather than tag them onto the end of someone else’s topic.
I’ve split your post to a new topic and given it a relevant title.
Depending on the format of your Passport Pro, the full path name may be too long (too many characters).
Try exporting to the local hard drive with a shorter file path - does that work?
The problem is the “/” (slash) character in the file name. Change it to “Sony(RMX) - Kranium-Justin Bieber.wav”
– Bill
This will be fixed on Mac in the upcoming 2.1.3 release of Audacity. However, using back or forwards slashes in file names is a bad idea if these files are intended for use on the internet or for people on other systems than Mac.
