Cant Edit or Add Gsnap! [SOLVED]
I recently downloaded and added gsnap and have it registered as far as i was instructed but i cant find it on my effects and have no i dea how to add new effects.
Please, if you need help, take a moment to read the pink panel at the top of the page and tell us your exact version of Audacity and Windows.
If you have Audacity 2.1.1, choose Effect > Manage… to open the Plug-in Manager. Select GSnap, click Enable then click OK.
If you have an earlier 2.x version of Audacity, click Edit > Preferences… , then the “Effects” section and enable the box for rescanning plugins at the bottom. Also ensure at the top that under “Enable effects”, “VST” is enabled. Then restart Audacity. In the dialog that appears, enable the checkbox for GSnap and OK.
Note that you must have the 32-bit version of GSnap. Audacity will not see the 64-bit version of GSnap, even if you have a 64-bit computer.
Exactly what i needed! Thanks for the help! :heart::heart::heart:
