Can't drop clips more than 5 seconds long or more
I am trying to import a clip and it keeps saying audacity couldn’t recognize the file.
I honestly Don’t know what is going on.
You have named the file with a “.mp3” extension, but it isn’t an MP3 file. It’s an MP4 file (AAC format audio).
To import the file, you will need to have FFmpeg installed (see: https://manual.audacityteam.org/man/installing_ffmpeg_for_windows.html) and you should rename the file with a “.mp4” filename extension.
