I am trying to export mp3’s in 48000Hz. But each track I export the export page defaults to 41000Hz. Is there a hidden way to make it default to the last frequency set?
It will normally default to whatever sample rate you imported, or recorded at.
Except MP3 doesn’t support over 48kHz so if you import a 96kHz WAV or FLAC I’m not sure what it will default to.
But it doesn’t “remember” the format, bit-depth, or bitrate that you imported.
OK no worries, and thanks ![]()
