Hello,
I cannot do any effect, as shown on the picture in link. All values are within bounds, but program says they are not.
I surely have the same problem as this personhttps://forum.audacityteam.org/t/cant-change-pitch-tempo-or-speed-nothing-works/42123/1 because I have Czech keyboard which also uses comma as default decimal separator.
I tried
-going into keyboard language settings and changing it to US, restarted PC
-try manually changing the decimal separator to dot in number formats and currencies and restarting pc
idk what to do anymore and I would prefer not to use other program.
I don’t have Windows 7 (it is now obsolete), but I think the problem is that you have conflicting settings regarding what the decimal separator is. You need to go through the Windows settings and ensure that the decimal separator is either set as a comma in all places, or a dot in all places. Check that in the “Regional and Language Options” that the “locale” (“regional setting”) is consistent with the number format settings.
Thanks for your help, but thats a little too much when I only want to edit a couple of files. Ill use something else and come back to Audacity after I upgrade to Win10
Hi, I’ve been having the same problem. I also live in the Czech Republic. I have a Windows 10 and the error still occurs. I also tried to change the preferences to “local settings” in audacity, but the program still uses commas instead of decimals. It’s truly infuriating.
Settings (or Control Panel) > Time/Clock/Language and Region > Region (Change date, time, or number formats) > (Region Formats) Additional Settings > Decimal Settings
