if I select a track it lasts one second. and no less. Obviously I would like you to select a shorter period. I have audacity on another computer and i can select milliseconds there. How can I solve the problem? Thanks for your help
De-select (disable) “Snap” in the toolbar at the bottom of the main Audacity window.
