"cannot save project"
:question: hello, first time here
i get an error message that says “cannot save project”
i recorded a song from my yamaha successfully but i cannot seem to save the song and then move on to convert to mp3
i am using a new mac.
i also might mention that i have used audacity with windows xp for years
i really am confused
regards
ron
Moderator note: Please do not tag new queries onto existing unrelated or vaguely related threads, it’s always better to start a new thread for a new topic. I split this off for you and gave it a more appropriate title.
Try File > Export for your song and save it to your Desktop as an AIFF (you can change the folder you save the song to).
Then Audacity > Quit Audacity and make sure your are following the installation instructions correctly: http://audacityteam.org/download/mac . You should not be running Audacity from the DMG, in case that is what you are doing.
