I am using Audacity 2.0.6 and Windows 7 Home Premium. I am trying to record podcasts. Until a week ago, saving recorded podcasts and creating export files of them was routine. Then, beginning last week, I could not save or export the recorded files. In each case, I am able to make the File-> Save Project and File → Export Audio… selections, with the corresponding Save Project and Export Audio windows appearing. I am able to enter the file name for the recording in each window. When I select the Save button, nothing further happens.
The log from the Audacity Log window shows:
10:15:56 PM: Audacity 2.0.6
10:15:56 PM: Trying to load FFmpeg libraries…
10:15:56 PM: Trying to load FFmpeg libraries from default path, ‘C:Program Files (x86)FFmpeg for Audacityavformat-55.dll’.
10:15:56 PM: Looking up PATH environment variable…
10:15:56 PM: PATH = ‘C:Program FilesCommon FilesMicrosoft SharedWindows Live;C:Program Files (x86)Common FilesMicrosoft SharedWindows Live;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program Files (x86)Windows LiveShared;C:Program Files (x86)Common FilesRoxio SharedDLLShared;C:Program Files (x86)Common FilesRoxio SharedOEMDLLShared;C:Program Files (x86)Common FilesRoxio SharedOEMDLLShared;C:Program Files (x86)Common FilesRoxio SharedOEM12.0DLLShared;C:Program Files (x86)RoxioOEMAudioCore;C:Program Files (x86)Common FilesAdobeAGL’
10:15:56 PM: Checking that ‘C:Program Files (x86)FFmpeg for Audacity’ is in PATH…
10:15:56 PM: Warning: FFmpeg directory ‘C:Program Files (x86)FFmpeg for Audacity’ is not in PATH.
10:15:56 PM: Temporarily appending ‘;C:Program Files (x86)FFmpeg for Audacity’ to PATH…
10:15:56 PM: Checking for monolithic avformat from ‘C:Program Files (x86)FFmpeg for Audacityavformat-55.dll’.
10:15:56 PM: Error: Couldn’t find symbol ‘avutil_version’ in a dynamic library (error 127: the specified procedure could not be found.)
10:15:56 PM: Error: Couldn’t find symbol ‘avcodec_version’ in a dynamic library (error 127: the specified procedure could not be found.)
10:15:56 PM: avformat not monolithic
10:15:56 PM: Loading avutil from ‘avutil-52.dll’.
10:15:56 PM: Loading avcodec from ‘avcodec-55.dll’.
10:15:56 PM: Loading avformat from ‘C:Program Files (x86)FFmpeg for Audacityavformat-55.dll’.
10:15:56 PM: Returning PATH to previous setting…
10:15:56 PM: Actual avutil path C:Program Files (x86)FFmpeg for Audacityavutil-52.dll
10:15:56 PM: Actual avcodec path C:Program Files (x86)FFmpeg for Audacityavcodec-55.dll
10:15:56 PM: Actual avformat path C:Program Files (x86)FFmpeg for Audacityavformat-55.dll
10:15:56 PM: Importing symbols…
10:15:56 PM: All symbols loaded successfully. Initializing the library.
10:15:56 PM: Retrieving FFmpeg library version numbers:
10:15:56 PM: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
10:15:56 PM: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
10:15:56 PM: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
10:15:56 PM: FFmpeg libraries loaded successfully.
I had this problem originally with Audacity 2.0.5 and upgraded to 2.0.6. The problem is the same with both versions.
Thanks for your help.
