Hello
I have a dell XPs 8930 and I’m running audacity 2.3.0
I finally am getting a signal into the program and I am able to record it however it is mono.
I have everything set as stereo, have gone into preferences> playback> record and all are set for stereo.
Everything is set for stereo.
I’m recording with one mic, in the input, in the front of the computer.
I have gone through the wiki, and know that audacity is automatically set for stereo, but that’s not happening.
I have never had this problem with other iterations of audacity with windows XP, or 7.
Help!!!
I appreciate all, and any help.
One microphone is mono.
[u]Stereo recording[/u] requires two microphones or a stereo microphone. And, the mic input on your computer is probably mono.
If you have a true-mono recording it will play through both speakers.
If you have a stereo recording with one silent channel, click the little drop-down arrow and select Split To Mono. Then click the 'X" next to the drop-down arrow to delete the silent track.
I get what you are saying one mic= mono
Here is the part that gets me:
I can plug a cheap radioshack mic into my wife’s laptop running audacity and it records in stereo.
Both L and R levels are flutuating when recording.
Both are doing the same in playback.
she is using windows 7, I’m using 10
Help…
The mic input could be wired differently, or the drivers might be doing something “unusual”. But of course it’s NOT true stereo and most computers/soundcards don’t work that way. Usually you get mono or left-only. If you have a stereo mic input it’s possible to use a stereo Y-adapter/cable to “split” a mono signal to the left & right connections. That will work with the line-input on ANY computer because line-in is always stereo, but some (most?) mic inputs are mono.
You can make a “dual mono” file with post-production (after recording) if that’s what you want. “Mono” audio CDs are made that way but in-general it’s a waste of disc space to have the same information duplicated in the left & right channels. If you rip a “mono” CD to MP3 you’ll also end-up with a “dual mono” MP3 file, but MP3 compression (when done right) is “smart enough” that it doesn’t compress the same information twice so the only downside is a file wrongly identified a “stereo”.
Everything from records & cassette tapes to FM radio, TV, and MP3 is mono-stereo compatible… If you play a mono recording on a stereo system it comes out of both speakers. If you play a stereo recording on a mono system, both channels are mixed together so you get all of the sound.
