Cannot record in stereo [SOLVED]
Windows 10, Audacity 2.0.6
I have tried the recommendations listed, but either I don’t get the options or it doesn’t work. I get the same single channel in both channels
What are you recording, what devices do you have and how are they connected?
http://www.kozco.com/tech/audacity/Documents/PostingQuestions3.pdf
I record vinyls with a Newmark turntable to a acer labtop. The connection is a USB-cable from the turntable.
Have you read this FAQ about how to set USB devices in Windows to stereo: http://manual.audacityteam.org/o/man/faq_recording_how_to_s.html#rinstereo ?
If it does not record stereo when set to stereo in Audacity and Windows the most likely explanation is a hardware fault in the turntable such as a mis-wired cartridge.
I have followed the FAQ and, when listening to the record, I get stereo
Apparently, I had not saved the changes to Windows - now it works. Myfault, excuse me
