I’ve been using Audacity for a few years, currently I use Audacity 3.1.3 and I’ve had this issue many times on many versions where Audacity cannot read an LOF file if there is an international character in a filename such as “úéåöä…etc…”
It’s easy these days on many O.S’s to have filenames with international characters.
Editing the file to replace the “offending” characters with one from the standard [a…z][A…Z][0…9] character set in a text editor and then changing the filename to suit has gotten me out of trouble each time but as part of an international choir I can’t stop the users using normal spelling of their names re-creating the problem every time I make a recording.
I wonder if it is possible that the dev’s could have a look at this to see if a wider character range can be accepted please.
Thanks for the reply Steve, I don’t know what encoding this is, but it’s an example of an LOF that won’t open without editing. Jam-20220319-230149532.lof.txt (672 Bytes)
I hope I’m not missing something stupid but if so at least it will be a resolution! This is still not working for me, I definitely have Version 3.1.3 on Win 10 with i7 16GB Ram.
I’ve have attached the Error and Build info as screenshots.
I’ve gone back over this and made the following changes and observations.
I reduced the size of the WAV files to a few seconds and made a copy without the “ú”
I edited the LOF so there is only the one file to open and again made a copy with “u” instead of the “ú”
A Hex dump of the “error” LOF file has 6 bytes for “Jesús” “0x4A6573C3BA73” but the other working file has only 5 for Jesus “0x4A65737573”
I attach a zip file of both versions, the only difference is the ú/u
I’ve finally been able to test on Windows, and you’re absolutely right - it fails with Audacity 3.1.3.
The good new is that it works with Audacity 3.2.0 alpha, and 3.2.0 is due to be released fairly soon (the last I heard was: “Q2 seems likely”).
I’ve also tried a few alternatives (attached…) which also didn’t work… by using the alt+key combination to enter the characters into the lof file úá and even entering possible hex values from charmap. I’m using Hex Workshop http://www.hexworkshop.com/ notworking2.zip (1.66 MB)
I’ve been working on a morse code encoder/decoder plug-in.
“Paris” is commonly used as a standard length word for calculating morse code speed. That file was just a test file that was close at hand.
