With Audacity 2.4.2, I am trying to open the file:
General
Complete name : Nobody reads this! - a3EqAw3_460svav1.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/mp41)
File size : 454 KiB
Duration : 7 s 174 ms
Overall bit rate mode : Variable
Overall bit rate : 519 kb/s
Writing application : Lavf58.45.100
Video
Format : AV1
Format/Info : AOMedia Video 1
Format profile : Main
Codec ID : av01
Bit rate : 453 kb/s
Width : 460 pixels
Height : 816 pixels
Display aspect ratio : 0.564
Frame rate mode : Constant
Frame rate : 29.970 (29970/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.040
Stream size : 397 KiB (87%)
Color range : Limited
Codec configuration box : av1C
Audio
Format : Opus
Codec ID : Opus
Duration : 7 s 22 ms
Duration_LastFrame : -18 ms
Bit rate mode : Variable
Bit rate : 58.8 kb/s
Compression mode : Lossy
Stream size : 50.4 KiB (11%)
Default : Yes
Alternate group : 1
However, it gives me the “Error Import” dialog with the link to file:///…/audacity/help/manual/man/importing_audio.html
FFMPEG library is detected as F(55.33.100), C(55.52.102), U(52.66.100).
On the side, it would be nice if the text throughout the application / dialogs is somehow selectable/copyable
