Cannot intall FFMPEG
I am trying to add FFMPEG to my Audacity. I do not have the option to locate the library. I have downloaded it and ran the install multiple times. I also deleted Audacity and reinstalled it as well. What can I do?
Audacity requires a special version of FFmpeg. Make sure you download and RUN FFmpeg_5.0.0_for_Audacity_on_Windows_x86_64.exe.
It should get installed to Program Files\FFmpeg For Audacity and you should be ready-to-go. You shouldn’t have to “locate” it manually. But you may have to restart Audacity.
Ah!!! I forgot about that one!!!
