Cannot get started
Helloooo! I have just downloaded Audacity to my pc. I Connecticuts the cables from my stereo, but the Button ”play” is grey and I cannot push it. D I ned some more configurations on the pc? Or what?
The Play button is grayed out as there is no audio to play. Try Generate > Chirp, then play.
How do you have this connected ? Generally you will need special cables, or some kind of an interface.
If you want to record what is playing on your stereo, press the Record button. If you want to hear what is being recorded you can try Transport > Options > Software Playthrough. If do this, there will be some delay.
To play what is on your stereo you may not need Audacity at all. Hold the Windows key and press “R”. Then type “mmsys.cpl”, and select the Recording tab. The select your stereo device, Properties, Listen, and check Listen to this Device.
