You posted in a portion of the forum where we can’t tell anything about you. We need to find out a lot more to diagnose the problem. Windows? Which one? Which Audacity? How much hard drive space do you have?
What kind of microphone and how do you have it connected?
That will give us a push. Please note that reinstalling Audacity doesn’t reinstall Audacity, so one step at a time.
Actually, I just fixed the problem. It seems all I had to do was unplug the mic and then plug it back in again. Then Windows detected it and all is good.
I have the same problem only different. When I push pause and record, the input meter goes all the way over and it’s in red. It doesn’t record anything either. I just bought a new computer and it uses windows 7. I have been using xp and version 1.3.something and I’ve never had a problem before. any ideas?
Hi
I have the problem that audacity does’t record the audio cassettes (neither waveforms nor playback).
I use Windows7, Audacity 2, the cassette player is connected to the computer trough AD-320 USB. The same worked last week, but then I suppose the boy of a friend changed anything…
The prefrences are set as indicated and I couldn’t find any solution in all the tutorials, faqs, etc. Recording via microphone works fine so I hope it’s not a problem of the AD-320 USB (I bought it a few weeks ago and it worked till last week).
I’d be happy about any hints… Thanks in advance!
yola
