If that isn’t the problem, please give steps to reproduce the issue (remember we can’t see your machine so you need to describe every detail of what we need to do to get the problem).
select something (it doesn’t matter wether I select with mouse or Edit → Select → some option, STRG + A)
i can’t edit it (every edit → “selected audio” option is grey) (is it “selected audio”? I have german controls, I mean the one below “copy to new audio track”)
Although now I see that I can edit via shortcuts. Whoopie!
That did’nt work last time either. Well, then I’ll learn them by heart and it’ll have to do.
Steve. If i click on edit and click select and then click all then the effects drop down darken and are usable. That is the only way it works for effects to function. Seems convoluted but works.
By default, Audacity will automatically select all of the audio in the project if none is manually selected, but perhaps you have inadvertently disabled that option. To check, go to:
“Edit > Preferences > Tracks”
and ensure that the option “Select all audio in project, if none is selected” is enabled (ticked).
