Cannot download pre-recorded Zoom audio as multitrack
I have Audacity 2.3.3 on Windows 10.
Zoom has the option of recording meetings in multitracks and I am using that option for podcast interviews. My understanding is that each participant (there are three in my meetings) is recorded in their own file. I have the plug in that allows me to download the Zoom recording in its original format (m4a) but when the recording opens in Audacity there is only one track. How do I separate the track so I can work on any sound issues for one speaker without affecting the sound/track of the other speakers? Can I download multitracks into Audacity or do they have to be recorded in directly?
Audacity does support importing multi-channel files.
You can check your file on this page: https://mediaarea.net/MediaInfoOnline
Thank you. Based on the info. below what I am downloading is 1 channel (I’m assuming this means 1 track for Audacity to read). Because Zoom states it will record a separate audio file for each speaker I was assuming I would download different tracks for each speaker.
General
Complete name : GMT20200401-205920_RuthannInterview-.m4a
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 51.7 MiB
Duration : 2 h 12 min
Overall bit rate mode : Variable
Overall bit rate : 54.4 kb/s
Encoded date : UTC 1954-04-01 20:59:20
Tagged date : UTC 1954-04-01 20:59:20
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 53.4 kb/s
Maximum bit rate : 124 kb/s
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 32.0 kHz
Frame rate : 31.250 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 50.7 MiB (98%)
Title : AAC audio
