Can we remove effects from a saved track?
Hi,
I accidently exit a project after applying “Base and Tremble” and “Echo” effects, saving the affected track, and saving the project. So I lost the original track (without effects). Can we remove these two effects from the track I saved? I still remember all parameters of these two effects I applied. This is Audacity Windows 2.4.2 version.
Your help would be greatly appreciated!
Thanks & regards,
Lee
You can reverse bass & treble (perhaps imperfectly) by doing the opposite… Boosting instead of cutting, etc.
But you can’t remove echo. :frowning:
Thank you for the information.
Regards,
Lee
