Hello:
I have down-loaded this program several times from several sites, including this one. On this one, I have tried BOTH the .zip file and the other one. When the system attempts to load the program, the following error message appears:
Creator Process failed: code 14001
The Application has failed to start because the application configuration is incorrect. Re-installing the application may fix this problem.
I have a valid copy of the lame encoder, and I used this program for one glorious day, last Sunday. I got my MP3 conversions done. Then, Sunday evening, I had to reformat my entire hard drive, due to a serious error, and I had to re-install all of the programs, which is all I keep on my hard drive. This is the last program I have to add, but I get the same error message no matter where I try to download it from. I want to report this, because it is an excellent little program, and others may be experiencing the same problem.
I am running Windows XP. Service Pack 2, Dual Core, 3GHz, 2 GB RAM. I don;t know what is happening here… any help would be greatly appreciated.
Thank you,
Karl1950
