can no longer record system audio?
I’ve upgraded to Audacity 2.3.0.
I’m using Windows 7 laptop with Realtek High Def Audio and Intel Display Audio. These are what show in Device Manager.
Previously, I could set Audacity to record system audio, so Any audio source or even media players, I could record the audio.
I’m not sure if the timing of the change coincides with a driver update, but it may?
So now there is no setting that allows me to record the system audio. I even tried to run a cord from output sound jack to input and still it seems it’s only able to record my room sounds?
Could this be my sound card? Or what can I do to try to work around this? If I could downgrade the driver, I might try that, just to see. Currently, it’s up to date, but I can no longer record system audio and I’m not sure why? I need to resolve this!
Very likely.
Windows 7 should support Windows “WASAPI”, so you should be able to record sounds that are playing on your computer using “WASAPI loopback” as described here: https://manual.audacityteam.org/man/tutorial_recording_computer_playback_on_windows.html#Windows_WASAPI_loopback_recording
