Hello all,
I would like to export track names.
I did searches on Internet but nothing came up on this.
Is it doable?
Thanks!
[Using Audacity 2.3.0 on Windows 10]
Hello all,
Is it doable?
Thanks!
Running this code in the Nyquist Prompt effect will give you a list of all selected audio tracks which you can then copy and paste.
;type analyze
;version 4
;debugflags trace
(format t "~a~%" (get '*track* 'name))
