Can I control the switching of outputs via scripting?
Hi folks
I spend a lot of my time switching between inputs and it would be convenient if I was able to do that via some kind of scripting.
Is there anything available to do this or is there a way that other people are doing it? Thanks.
ododo
That’s not something you can do with Audacity’s built-in scripting. It may be possible to do with AppleScript. A quick Google search brought up: terminal - Any way to change sound output device via Applescript or shell? - Ask Different
Hi Steve
Thanks for the reply.
I use a utility called SwitchAudio to switch between system outputs.
I’d like to find a similar way of doing the same with Audacity outputs.
I’ll see if I can find a way to do it in Automator.
Thanks
ododo
