Hi
I use audacity for all kinds in things to help teach physics here in the Uk running courses for training and in-service teachers.
Essentially we use Audacity as a data-logger for experiments that make a sound (or we wiggle a magnet near a wire to make a ‘pseudosound’)
In the new version 2 on the Selection Tool-bar the highest resolution you seem to be able to set is when you right click on it is hh:mm:ss + milliseconds when you go to a higher resolution this shifts things into samples and so an actual clock time is not shown.
we often measure quite short times (you can measure the speed of sound in a lab with a pair of headphones and a loud clap, it’s really cool (http://audacityphysics.pbworks.com/w/page/41219781/Speed%20of%20sound%20in%20air)
Whilst we could convert the samples back to timings is there a way to get the program to give a timing for a selected waveform (or highlighted subset of waveform) to a higher direct time than hh:mm:ss + milliseconds as is had done in previous versions.
If there is a way can someone let me know how to do it, this is just magical as a software tool for physics teachers and always goes down really well on the courses I run
if any teachers are lurking my proto audacity physcis wiki is here http://audacityphysics.pbworks.com
Thanks
james
