Can Audacity create MusicXML file?
If I load a WAV audio file into Audacity, can I convert it into a MusicXML file? If so, the MusicXML could then be loaded onto a software such as Musescore and the audio / song, should display as sheet music notes! This would make a great music Transcriber, I am hoping(?)
Thank you.
No, Audacity can’t do that.
Converting audio to score notation is very difficult for a computer to do. Typically this type of feature is only available in specialist (expensive) software such as Sibelius AudioScore, and even then the conversion usually requires a lot of manual editing to get a usable score.
