Hi all,
I use Audacity 2.0.3 to export mp3 files to m4a. Most of the time the export is fine. But sometimes, the end result is an empty file and I can’t understand what causes the error.
Please try for yourself with the attached file. Can you help me? Is this a bug?
In case, this may help, the log below.
Nicolas.
11:25:08: Audacity 2.0.3
11:25:19: Trying to load FFmpeg libraries...
11:25:19: Trying to load FFmpeg libraries from default path, 'C:Program Files (x86)Ffmpeg For Audacityavformat-52.dll'.
11:25:19: Looking up PATH environment variable...
11:25:19: PATH = 'C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;c:Program Files (x86)ATI TechnologiesATI.ACECore-Static;c:Program Files (x86)Common FilesRoxio Shared10.0DLLShared;c:Program Files (x86)Common FilesRoxio SharedDLLShared;C:Program Files (x86)QuickTimeQTSystem'
11:25:19: Checking that 'C:Program Files (x86)Ffmpeg For Audacity' is in PATH...
11:25:19: Avertissement :FFmpeg directory is not in PATH.
11:25:19: Temporarily appending ';C:Program Files (x86)Ffmpeg For Audacity' to PATH...
11:25:19: Checking for monolithic avformat from 'C:Program Files (x86)Ffmpeg For Audacityavformat-52.dll'.
11:25:19: Erreur :Impossible de trouver le symbole « avutil_version » dans la bibliothèque dynamique (erreur 127 : the specified procedure could not be found.)
11:25:19: avformat not monolithic
11:25:19: Loading avutil from 'C:Program Files (x86)Ffmpeg For Audacityavutil-50.dll'.
11:25:19: Loading avcodec from 'C:Program Files (x86)Ffmpeg For Audacityavcodec-52.dll'.
11:25:19: Loading avformat from 'C:Program Files (x86)Ffmpeg For Audacityavformat-52.dll'.
11:25:19: Returning PATH to previous setting...
11:25:19: Actual avutil path C:Program Files (x86)Ffmpeg For Audacityavutil-50.dll
11:25:19: Actual avcodec path C:Program Files (x86)Ffmpeg For Audacityavcodec-52.dll
11:25:19: Actual avformat path C:Program Files (x86)Ffmpeg For Audacityavformat-52.dll
11:25:19: Importing symbols...
11:25:19: All symbols loaded successfully. Initializing the library.
11:25:19: Retrieving FFmpeg library version numbers:
11:25:19: AVCodec version 0x344802 - 52.72.2 (built against 0x344802 - 52.72.2)
11:25:19: AVFormat version 0x344002 - 52.64.2 (built against 0x344002 - 52.64.2)
11:25:19: AVUtil version 0x320f01 - 50.15.1 (built against 0x320f01 - 50.15.1)
11:25:19: FFmpeg libraries loaded successfully.
11:25:19: File name is c:usersnicolasdocumentsprojet jeuxsoundsound on ubuntu devorganic_nav_11.mp3
11:25:19: Mime type is *
11:25:19: Opening with libsndfile
11:25:19: Opening with libmad
11:25:19: Open(c:usersnicolasdocumentsprojet jeuxsoundsound on ubuntu devorganic_nav_11.mp3) succeeded
