HI there,
I have just installed the latest version of Audacity (3.4.0) and came across a problem, which makes this version unusable for me.
I use Audacity for processing multiple tracks having 384 kHz sample rate. When I now export multiple tracks using “file => export audio => multiple-files” all files are exported having a sample rate of 44.1 kHz regardless of what is set in the export dialogue box or what the track sample rate is.
Exporting just one track works fine and the multiple track export also worked fine in the previous versions
Is this the right place to report such a bug? And is there any chance that this problem gets rectified in the near future?
This is a known and logged issue that has been fixed for the upcoming 3.4.1 maintenance release.
Peter
