With Audacity 3.3.3 and macOS 13.6 (22G120) running on Apple M2 Max processor in Mac Studio computer with three Apple Studio Displays and one ViewSonic VP3256-4K display connected.
When I play audio, it always plays out of the speaker in the third Studio Display. In Audacity/Preferences/Audio Settings/Playback I can select the device using the pop-up menu. I can see all four of my displays. The three Studio Displays all have the same name, “Studio Display”, in the pop-up menu. The third Studio Display is selected. The settings menu allows me to change my selection to the second Studio Display, which I did and clicked OK. However, once I close the settings window and try to play audio, it still comes out of the third Studio Display. Checking the Preferences, the selection has reverted to the third Studio Display.
I suspect this problem is a result of the names of the three displays all being the same. I cannot do anythign about this fact. macOS does not allow the user to change the name of a display device. I can successfully select the VP3256-4K because it has a different name. I suspect that whenever there are multiple displays with the same name, Audacity will always choose the last one.
I have not been able to find any workaround for this bug. If I want to play audio from a Studio Display, it has to be from the third one.
