Bug in FFmpeg conversion? Work around found : )
More adventures in video editing.
Copy VOB in Audacity
Use Change Speed to get size 00:15:02 + 43,153 samples
Use Noise Reduction to get rid of DVD recorder motor noise
Save as AC3
open AC3 in Audacity
Use Change Speed to get size 00:15:02 + 43,776 samples
or
00:15:02 + 22 PAL frames
00:15:02 + 23 PAL frames
or
43,339,153 samples
43,339,776 samples
Don’t see anything on front
Don’t see anything on back
Listening test of seconds 2 to 3
look and sound the same.
Is this a bug?
makes it that much harder to fix my VHS to DVD video conversion.
Why are you using Change Speed twice? Noise Reduction does not change the duration, so after changing the length to 00:15:02 + 43,153 samples in the first step, the third step should be unnecessary.
Be aware that AC3 is a lossy format. Lossy compression formats discard some information as part of their effort to reduce the file size, so there is an inevitable loss of sound quality. Also, as with MP3 (another lossy compression format), the start of AC3 files are padded with a small amount of silence up to the first frame boundary, so the exported length will be a little longer than the length of the audio that you are exporting from Audacity.
To guarantee the correct length and avoid loss of sound quality, it is better to export in a lossless format such as WAV.
What are you expecting?
Thanks for the help,
discovered your most helpful suggestion just before I read this.
I just made a AIFF copy of the noise reduced file
and it is 00:15:02 +22 PAL frames
I used Change speed ONLY to verify the exact length of the file,
maybe there is an easier way
I went with AC3 because that is what most videos do, right?
Was hoping the “extra” samples where at the beginning or end of file
where I could easily delete.
Did not find that to be the case.
The file is just slightly longer than the original (not lossy)
and for most purposes that would be ok
but 1 frame is a killer for audio video synch : (
It is a BUG
Oh and Filmora uses AIFF files.
Have not tried yet but am alway hopeful
Double click on the track to select it, then look in the “Selection Toolbar” https://manual.audacityteam.org/man/selection_toolbar.html
By default, the final time box shows the time at the end of the selection.
Yes, but when the audio and video are encoded together they can be synchronised by the container format. When you are encoding the audio separately there is no such synchronisation. If you import the audio into your video editing application in a lossless format, then export the video+audio from that program, the video editor should handle the encoding of both the audio and the video and ensure that they remain synchronised.
AIFF is also a lossless format, so that should be as good as using WAV (AIFF is more common on Macs than on other computers).
