Bug in Audacity after creating stereo track from two mono tracks
Audacity crash report.txt (157.8 KB)Hello.
I’ve tried to create stereo tracks with two mono tracks and I’ve got this crash. I can’t send crash report, I don’t know why. So, I’ve attached It here.
Thank You.
Marco Oros
Are you using Make Stereo Track, or doing it some other way?
Right. I use make stereo track from the track’s menu.
I’ve tried It differently. I’ve divided My recorded stereo track and after that, I’ve tried to make stereo track. After that, I’ve got same problem.
One note: In report is written, that I use Windows NT. I use Windows 10 (64-bit). I can create stereo tracks using mix & render, but what It causes problem, when I use make stereo track from the menu? Please, could You look on It and fix this issue? Or, You haven’t such problems? I’d like to be sure, because maybe I have made something wrong on Audacity.
Maybe It is My bug, but I don’t know why. Please look at first post on the attachment, what causes the problem. It is in new Audacity 3.4 update and also, I use Windows 10 (64-bit).
I’ve tried It on both versions of Audacity, 32-bit and 64-bit. Previous versions don’t cause this problem to me.
