Hello,
I am using the brilliant feature in Audacity that enables the import of an LOF List of Files with their offsets.
I have noticed 1 Bug and 1 Limitation.
Bug:
Exporting the LOF file to wav results in a file where the offset of the first wav in the LOF is ignored.
Instead of starting at the mentioned offset, the first wav is at zero time. The rest are fine in their relative positions.
This is only noticed after exporting the wave file. Upon opening the LOF file everything looks fine.
I have just found out that running this command (open LOF, export WAV) as a Chain, does not produce this error, which is a great workaround.
Normally, I am having to export the LOF as wav, then importing and manually adding the first offset and having to re-export.
Limitation:
My files consist of 2 second or 3 second clips at most and I am able to import only about 200 Files at a time.
Above this number, Audacity imports even upto 800 files, but upon attempting to export as Wav, throws an ‘out of memory’ error.
If this could be rectified, allowing the total number of files/tracks imported to have no limit, it would be great.
I can confirm that the length of the ‘stack’ is only about 2 hours. But the ‘out of memory error’ seems related to the number of files that are getting imported as separate tracks.
Currently I have to split my LOF files to contain only upto 200 clips. export each LOF to wav. then concatenate them again manually after adding the missing offset as mentioned above.
I would like to state again that this feature is a most brilliant one and allows audio to be manipulated and resynchronized in a simple manner.
Thanks in advance.
