Windows 10 Home, Version 1709, Build 16299.309
Audacity 2.3.0 alpha, build 20180320-91, 20180321-92
Click Tools | Macros
Choose macro that includes EQ, Normalize, Export to MP3
Click Files…
Select multiple files
Click OK
Click Save, OK for each file
Click Cancel in Manage Macros window
Audacity Crashes
March 21, 2018, 12:55pm
2
Thanks for the report.
A crash has previously been reported on Mac and Windows when the macro includes “Export to MP3”.
Could you test if the crash still occurs if:
You remove the “Export to MP3” step
If you replace “Export to MP3” with some other export
If you remove or replace the other effects from the macro to determine if the export step is the problem.
Here are results of the requested tests:
Export to OGG instead of MP3
Same crash
Remove Export step
Equalize, Normalize
Same crash
Remove Normalize step
Equalize only
Same crash
Replace Equalize with Normalize
Normalize only
Same crash
I think this has alraedy been fixed the the developer who is working on Macros
See: https://github.com/audacity/audacity/commit/40085b384f48d097230f5dfee8786eb4eaa96c76
Confirmed: bug fixed; Build 96 works without crashing.
Thanks for reporting back Stuart - much appreciated.
Just be aware that the transition to Macros is still very much a work-in-progress - there are still a few" wrinkles" we have to iron out …
See this Wiki page: https://wiki.audacityteam.org/wiki/Macros_discussion_page
Peter.
This is really wierd. It doesn’t happen for me.
I am trying to reproduce this error.
Best regards
Peter Storm
[Banned website]
August 31, 2018, 6:31pm
8
This bug was reported for Audacity 2.3.0 which is the current alpha version of Audacity. Are you testing the alpha version, or just trying to spam the forum?
KDavid
November 2, 2018, 3:45pm
9
I’m still getting this crash. I’ve been applying a “Chain” that includes Equalization to five other files and it worked perfectly. Now I have a new project and can’t apply it. I’ve upgraded to 2.3.0 and still get the crash. I’ve also tried to simply record a brand new track in a brand new project and ONLY apply equalization (instead of the whole “Macro”) and it still crashes. Help?
November 2, 2018, 4:32pm
10
Does it crash if you apply the Equalization effect directly (not from a Chain / Macro)?
