break markings for vinyl to cd.
How do I mark my recording from vinyl to cd so that the breaks are identified on the cd player I am using 2.0.2
Audacity 2.0.2 is obsolete. The current version is 2.1.1 which you can get here: http://web.audacityteam.org/download/
To create separate tracks on a CD, you need to export each “song” as a separate file. Then use your CD burning software to add each of the files to the CD compilation.
More information can be found in these tutorials: http://manual.audacityteam.org/o/man/tutorial_copying_tapes_lps_or_minidiscs_to_cd.html
I usually use one “long” WAV file, a [u]cue sheet[/u] with [u]ImgBurn[/u] to set the track markers on the CD. This also works well if you have a “live” recording and you just want track markers on the CD with no gaps or glitches between songs.
I start by combining both sides of the LP into one file. That way any noise reduction, EQ, volume adjustments, or other effects & processing gets applied equally to all songs.
You can create or edit a cue sheet in Windows Notepad and you can start by copying & pasting from the online examples. Then you just need to change the file name and start times, etc.
There are other burning programs besides ImgBurn that can use cue sheets, but that’s the one I’ve been using for a few years.
