I’m trying to figure the best setting to record my trumpet playing. It always really hard on the recording. Is there any suggestions for the settings? Thanks Gary
That depends on what equipment you are using.
With a dynamic mic plugged into a USB mic pre-amp, it should be quite easy - certainly easier than recording something that is very quiet.
