Boost & Sweep EQ
I am learning about EQ and have been watching a bunch of youtube EQ tutorials - one of the techniques I have seen demonstrated is to “boost & sweep” frequencies while in EQ in order to listen for specific frequencies that need some adjustment - can this be done in Audicity EQ?
(Windows 10; Audacity 2.2.2)
Unfortunately Audacity cannot do that yet.
OK - thanks for your response
If you search with your favourite search engine, there are several free VST parametric filters that will probably do what you want, because VST effects in Audacity have “real-time preview”. Try searching for “free parametric vst”.
