Bluetooth recording
I’m lookingbto buy a new turntable that has Bluetooth, as does my PC. TT doesn’t have USB output though. Can I still rocord just uding the Bluetooth connection to the PC
I’m not 100% sure but try it with your cell phone first. Check to see if it shows-up as a Recording Device and if so, try it.
USB would probably be easier & more foolproof…
I assume the turntable has analog line-outputs? If you have a desktop/tower computer with a soundcard you can connect line-out to line-in (blue) on the soundcard.
Or there are USB audio interfaces with line-in, like the Behringer UCA202.
