version 2.4.2 Has worked good previously, but sound recording will burn, & no data on cd. The track will play on WMP>
Audacity doesn’t burn CDs.
What software did you use to make the CD?
I assume you’re trying to make an audio CD? (You can burn audio “data files” such as WAV or MP3 onto a disc and that’s different from an audio disc which doesn’t have regular computer files.)
Did you make a WAV file?
Yes, made WAV file, but problem solved, the burn option was set on data somehow, then it worked. thankyou.
Thanks for reporting back. Glad you were able to find a solution to your problem.
