Bit Rate
Help
I’ve forgotten how to change the bit rate on a given project. Can someone help?
Bob H
Audacity 2.0.3
Windows 8
If you mean for MP3 export, in the Export window, choose “MP3 Files” then click the “Options…” button bottom right of the dialogue.
If you meant bit depth (32-bit float versus 16-bit or 24-bit), look in the Quality Preferences under “Default Sample Format”.
Thank you Thank you…somedays I have more senior moments than others.
Bob H
