I’m using Audacity 2.1.3 on windows 8.1 pro.Which is the best freeware to create bass lines so that I can use it in Audacity,like for drums I use Hydrogen which have been good till now and easy to use too.Could you kindly suggest.Honestly, I do not have the means to buy a software .I obtained Audacity via a .exe installer
