Tested Microphone in computer sound settings and it’s working fine.
Windows 10
Audacity 2.4.2 (checked also on 2.3.1 and the same problem).
the thing is i have another computer (windows 7) with the same audacity version and it’s working fine.
The software reads the deivce but as i click record no sound input is shown.
suggestions?
thanks
2
Do you mean that it records a flat line - silence?
yes
on the computer sound settings test it works fine
and I did the privacy thing on Windows:
Open Settings–>Click on Privacy–>Click on Microphone–>Turn on the Allow apps to access your microphone
still doesn’t work
the computer reads the mic. I did a sound test and it’s working.
any ideas what can the problem be?
7
I assumed that meant that you had solved the issue. As it doesn’t mean that, what does it mean?
