been using Audacity for ages and now cant record from
Using Audacity for ages. Got a windows upgrade and now cannot record from you tube. Not sure why everything is setup correctly. My drivers are all current as is my audacity? Any suggestions.
[u]Tutorial - Recording Computer Playback on Windows[/u]
What did you select as your recording device?
I am using a audiobox usb and it shows correctly.
The Audiobox normally records from a microphone or whatever is plugged into it.
If you are listening to the audio audio through the Audiobox there might be a loopback option that will work. The loopback device has to match whatever device is playing the sound.
Or you can connect physical loopback cables (and Y-splitters since you’ll want to keep the speakers connected).
