batch resample
Hi,
I found an answer to this dated 2013 and wanted to know whether a solution is now available.
I have many (~300) wav files with a sampling rate of 500 kHz. I want to resample these at 48 kHz and export them using a batch function or chain. I found that I can’t change the project rate or use the track > resample commands in a chain though.
Is there a way to do this without importing all the files, manually changing the project rate, and then exporting the files?
Best regards,
Chris
Try [u]TAudioConverter[/u] (drag & drop multiple files). Or, since you seem comfortable with the command line and scripting, try [u]SoX[/u].
I don’t know if either of these can open a 500kHz audio file… I’ve never seen a 500kHz audio file.
SoX should work.
Out of interest, what are these files that have a 500 kHz sample rate? That is a massively over the top high sample rate for audio :open_mouth:
Thank you for your replies - I will try both methods and let you know which works best. The 500 kHz sampling rate is for recording high frequency, marine mammal vocalizations using a towed array of hydrophones. Harbour porpoises around the UK for example, click like bats at around 130 kHz. Makes for big files, and when i review the files for the mid-low frequency calls of other species, resampling them to 48 kHz or less makes them easier to handle.
Wow, I never realised they went that high :open_mouth:
Hi again.
Ok - I’ve run the windows SoX installer. When i run sox.exe should i get a command line interface? A command line-looking black screen just whizzes past in half a second. I’m on Win7 64 bit.
It looks like the software I need to do the resampling though, if i can figure out how it works. I’m not sure how to reference my folder of input files and a location for the output. I know this isn’t a Sox forum, but any help would be appreciated.
Thanks,
Chris
You need to open a command prompt window.
I don’t use Windows, but this looks like it should have something that works: http://www.7tutorials.com/7-ways-launch-command-prompt-windows-7-windows-8
http://sox.sourceforge.net/sox.html - see “Synopsis” at the top of the page.
sox-users List Signup and Options
SoX - Sound eXchange / Mailing Lists / Search
Thanks very much for your help.
I used Sox and the example bat file that comes with the installation. I modified the bat file for 48 kHz resampling and could drag a batch of files onto the bat file in windows explorer. It let me do about 130 files at a time (just closed itself if i tried to do too many at a time).
So thanks - SoX worked fine for me. I did experience a problem with Audacity step prior to resampling… if you are interested please see my last post (‘opening audio’).
Chris
