Batch processing Macro in Mac (Monterey) not working
Hi, when I select a batch of files for processing (using the macros), I get the usual window saying it’s processing the files. However, when it’s done, I can’t find them, or to be precise, nothing’s happened.
For your information, I’ve created the directory for the Macros out put (Preferences > Directories > Macros output), but there’s nothing there after running the macros.
Any suggestions?
Does your macro end with one of the “Export” commands?
That was indeed the problem, I didn’t realise you had to include the ‘export as …’ in the macro.
Big thanks.
